With two race cars being housed there is a need for more space. Recently added this pallet rack industrial grade. Got it used for under $200.
There are enough beams and shelving for a third shelf but for now there will be just two.
Mostmint Garage
Mostmint Garage
Re: Mostmint Garage
All you need is one more upright piece and you could double your storage.
Re: Mostmint Garage
Finally got around to attaching the air hose reel to the air line. Right now it’s above the tool box if that proves to be a pain I’ll move it.
Re: Mostmint Garage
The jack looks the same, but this past weekend I oiled the rear wheels and cleaned the axles and greased the front wheels. It's like a new jack! It's well over 30 years old but still doing the job.
Re: Mostmint Garage
The business of spreading rust dust around the garage is coming to an end soon.
I temporarily rigged this up today and it worked perfectly pulling in all the rust as I cleaned a couple bolts. I'm planning to make a bracket to slip the hose in to make this a quicker setup.
